If no encryption is used for POP3 server in Message Control, the runtime stops responding
When no encryption is used in the configuration of SMTP mail for the POP3 server, the runtime stops responding when mails are polled the first time.
An issue was addressed where the SMTP connection referenced the wrong field for encryption configuration. Now the runtime stays responsive when polling mails from unencrypted POP3 servers.
Issue Number: 32722
Fixed on Date: 25.9.2014
Versions: 7.10 0 BUILD 15071 | 7.11 0 BUILD 15093
Checklist: Message Control
Server is not responding to user actions if SMS gateway method is used in a redundant system
Summary If a redundant system is used in combination with Message Controls SMS gateway dispatching method, after some time the runtime on the server is no longer responding. Description If a redundant system is used in combination with Message ...
FAQ: Message Control || VoIP message is sent but can’t be heard
In a VoIP message the audio file can use several codec formats for its compression. When a call is set up, then sometimes some target providers already play back the ringing to the call as an audio stream. This can be done in several or one specific ...
FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
Checklist: OPCDA Server
Time estimate: 20 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Do NOT use DCOM in combination ...
