If a context menu is copied and pasted in the editor and then used on a different element, behaviour is not like expected. In the runtime, it seems like the copied element has no action at all. After the original context menu was called for the first time, the copy takes the behaviour of the original.
An issue was addressed in the Menu module where IDs were not copied correctly. Now, the menu takes the unique ID from the element.
Fixed on 12.06.2012, available from 7.00 SP0 Build 1, available from 6.51 SP0 Build 14
