IEC870: time synchronisation executed despite higher than configured Max. time difference" (0 seconds)"
time synchronisation does not use milliseconds for checking maximum time difference
Issue Number: 203730
Fixed on Date: 4.12.2019
Versions: 8.10 0 BUILD 62573 | 8.00 0 BUILD 62925 | 7.60 0 BUILD 63571
FAQ: What is the time zone and time format used in zenon Software Platform products and what needs to be considered?
When you ask someone what the time is, they'll usually be able to tell you. But when you ask them what date and time sunrise was yesterday in a different country on a different continent, in a different hemisphere it gets less easy. Terms like GMT ...
Buttons configured as pushbuttons never reset after holding time, keeping the on-value set.
Summary In the Service Engine pushbuttons are not reset after the holding time. This has been fixed Description In the Service Engine, buttons that are configured as pushbuttons are not reset after the holding time. They retain the switch-on value. ...
Double Cursor present wrong value "1" even the 1st/2nd cursor's var value is "0" when time difference is "0"
Description In Extended Trend, the double cursor shows the wrong average value “-nan(ind)” when using numeric variables, even if the value of the 1st and 2nd cursor is “any”. The problem occurres when the double cursor’s time difference second is set ...
