IEC870 driver, when sends TESTFR shortly (<10ms) after reception of spont ASDU, is not acknowledging this ASDU, and slave closes connection
IEC870 Driver discards all incoming I-Frames when waiting for "TESTFR con".
probably when you deactivate the TEST-procedure (T3=0), but this means that driver will not detect connection losses while slave has no spont data.
Issue Number: 190533
Fixed on Date: 6.8.2019
Versions: 7.60 0 BUILD 59794 | 8.00 0 BUILD 59775
    • Compatibility problem with Access IEC60870-5-104, can't load setting from XML
      Description After updating zenon Software Platform to a build that supports IPv6, IEC870 Master does not get a connection to IEC870 Slave in 101-Unbalanced mode.. This has been fixed. To benefit from this fix: Update your zenon Software Platform to ...
    • Process Gateway IEC 60870-5-101 slave does not send a correct response when an unsupported ASDU is received
      Summary When an unsupported ASDU is received the 870 101 slave did not correctly send a link layer confirmation, causing a communication interruption Description When an unsupported ASDU is received the 870 101 slave did not correctly send a link ...
