IEC870 driver logs misleading WARNINGs by reception of ASDUs with command confirmations
The IEC870 driver logs misleading warnings with the statement: "Received incompatible type identification".  This has been fixed.
The IEC870 driver logs misleading warnings with the statement: "Received incompatible type identification" when receiving ASDUs with command confirmations (IOs in controlling direction). This happens if there are variables in the project that represent IOs in monitoring direction with the same COA and IOA as their commands. This error was caused by changes in versions zenon 10, build 114699, and higher, which were made for bug #259574.
This issue has been resolved.
  • Update your zenon Software Platform to the latest build of zenon 10 or higher, at least Build 140012.
Item ID: 264581
Version: 11.00 Build: 157700
Version: 10.00 Build: 144352
