iec870 driver does not transfer to SE new values of command variables if the old value had status bit OFF
The IEC 870 driver does not update values of command variables in the Service Engine if old variable values have status bit OFF. This behavior has been modified.
The IEC 870 driver does not update the values of the command
variables after driver stop and start commands via zenon driver functions. The
command variables of type ID T45..T64
keep the status bit OFF and their old
value. With 'Write set value" the driver sends the command to the PLC, but
there is no update in the Service Engine, neither when driver sends command nor receives command acknowledgement from PLC.
Therefore it is no longer possible to process commands
via Command Processing. The user must restart the Service Engine to
continue processing commands. This error has been introduced with build 116045 for zenon 11
and 12.
This error has been fixed. The IEC 870
driver now updates the current values and status bits in the Service Engine
again.
higher.
Item ID: 264582
Version: 11.00 Build: 157700
FAQ: How can I monitor and react on the communication status of my devices with zenon?
OPC UA driver communication issue when switching driver status from Simulation mode to Hardware mode while SE running
Description The OPC-UA driver does not communicate correctly with the OPC-UA server after switching from simulation mode to hardware mode and back to simulation mode while the Service Engine is running and the OPC-UA server is not connected. ...
