IEC850: driver stuck while reading ctlModel (CF) for sending command (because data object is a structure?)
reading ctlModel works again with structured DATA
Issue Number: 142968
Fixed on Date: 17.7.2018
Versions: 7.60 0 BUILD 49532 | 8.00 0 BUILD 50155
IEC61850 Server is not responding Cancel command when Data Object is not selected
Summary If a client sends request "Cancel" for Data Object which is not selected, the IEC 61850 Server does not react there is no response on this (erroneous) request. The server shall react using response+. Description If a client sends request ...
Bug: Write Error to setVal[SP] on IEC 61850 Server
Description The IEC 61850 Server fieldbus driver accepts the write requests for read-only ('RO') data attributes (variables) with FC=SP; e.g. */setVal[SP]. And it refuses the write requests for data attributes with FC=CF, if SCL-configured as 'Set' ...
Logix_ODVA Driver gets unhandled exception when reading specific BYTE structure
Summary When having a USINT variable inside a complex structure e.g. Structure.my_usint it can cause under special circumstances a unhandled exception. Description When having a USINT variable inside a complex structure e.g. Structure.my_usint it can ...
