IEC850 driver does not behave according to the latest version of the standard - client must actively reserve the BRCB even if ResvTms is -1
The IEC850 driver omits the reservation of BRCB, if the BRCB instance is already pre-reserved (when attribute ResvTms is -1). But the driver should reserve it (write BRCB.ResvTms > 0) also in this case.
Background information: According to IEC61850-7-2 amd1 Ed.2 (called Edition 2.1) it became mandatory for a client to reserve the BRCB actively. This applies even if the BRCB instance is already pre-reserved for this client via the SCL file. The client must write a value > 0 for ResvTms before configuring and activating the BRCB if the ResvTms attribute is present in the BRCB.
Solution: The behavior of the driver has been adjusted the the updated statement in the standard.
Item ID: 258598
Version: 11.00 Build: 112904
Version: 10.00 Build: 112170
    • IEC 61850 Client driver in Logic should have configuration settings BufTm, IntgPd, OptFlds like zenon iec850 driver has
      Summary zenon version 7.20 has introduced in zenon IEC61850 (client) driver new configuration settings, but not in the Client driver in straton/Logic. The driver configuration RCB settings: Buffer Time, Integrity Period and Optional Fields should be ...
    • Checklist: zenon Driver does not start in zenon 11 Engineering Studio / Service Engine.
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenDrvOpsManager is no longer ...
