IEC850 Driver Configuration wizard: List nodes cannot be expanded or miss information
Issue Number: 217458
Fixed on Date: 20.7.2020
Versions: 8.10 0 BUILD 67223 | 8.20 0 BUILD 67231
    • Checklist: zenon Driver does not start in zenon 11 Engineering Studio / Service Engine.
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenDrvOpsManager is no longer ...
    • Driver configuration cannot be opened and also no new driver can be created.
      If a Service Engine is started as a windows service also zenDrvOpsManager is running as a service. Thus zenDrvOpsManager cannot open a user interface for driver configuration and the Engineering Studio seems frozen. Running a Service Engine as a ...
    • Redundant License Configuration
      Starting from zenon version 8.00 it is possible to share each license over the CodeMeter network. This allows you to have a dedicated license server. The license server can be any PC or virtual machine which runs CodeMeter. One license for two ...
