The IEC 61850 driver configuration wizard does not read SCD files correctly from zenon 8.10 onwards. Reading is started, but the wizard is then closed with an unhandled exception. In zenon 8.00, reading takes place without errors.
This is caused by fields that are not present but are expected by the wizard.
This has been fixed. When loading SCD files, non-existent fields no longer lead to an error.
