IEC61850 Server when an URCB is enabled but all triggers options are disabled than the reports are emitted
Issue in IEC61850 Server (zenon Logic I/O driver): when an URCB is enabled but all triggers options are disabled (test case, has no practical use) than the reports are emitted by dupd (caused by change of timestamp) and Sequence Number is increasing.
Now when report does not contain data then is omitted.
Note: issue has impact on test case RpN2.
Issue Number: 31117
Fixed on Date: 16.1.2014
Versions: 7.10 0 BUILD 9760
    • IEC61850 Server should refuse write to Resv when the URCB is enabled or already reserved by other client
      Summary zenon Logic I/O driver IEC61850 Server should refuse any write to data attribute Resv (Reserved) in URCB (Unbuffered Report Control Block), when Resv is TRUE or RCB is enabled (RptEna=TRUE) by other client. Description zenon Logic I/O driver ...
    • Checklist: OPCDA Server
    • Checklist: Client/Standby cannot establish a reliable connection with Service Engine Server
    • Bug: Write Error to setVal[SP] on IEC 61850 Server
      Description The IEC 61850 Server fieldbus driver accepts the write requests for read-only ('RO') data attributes (variables) with FC=SP; e.g. */setVal[SP]. And it refuses the write requests for data attributes with FC=CF, if SCL-configured as 'Set' ...
    • Webclient and server hangs if Reports are executed
      Summary When executing Reports (Module: Report Generator) in a project leads in network projects to the issues: - Server hangs if you open several pics - Webclient crashes if you open several pics Description When executing Reports (Module: Report ...
