IEC61850 Server uses new TimeQuality value also for existing values of t-attributes
The zenon Logic I/O driver IEC61850 Server uses new TimeQuality (global setting) value also for already set values of t-attributes, i.a. for polled variables (not included in any Report) having t-attribute value from time before TimeQuality change.
In case of TimeQuality 'Clock not synchronized' and 'Leap Second Known' the driver should use current TimeQuality only to currently updated stVal, q or t-attribute values, as clock probably still delivers acceptable timestamps. In case of 'Clock Failure' is not possible to recognize if the timestamp is wrong or not. But even then a better solution is to affect only new value of t-attributes.
Driver should append current TimeQuality only to t-attribute value which changes, thus when:
- t-attribute variable is created in Logic program and its value changes
or
- there is no t-variable in Logic program and q or stVal value changes. So when driver automatically updates t-attribute in the Data Object.
or
Timestamp quality is now updated only when the value of any of the allowed timestamp update attributes changes.
Issue Number: 28923
Fixed on Date: 26.2.2013
Versions: 7.00 0 BUILD 8 | 7.10 0 BUILD 5560
    • Checklist: OPCDA Server
    • FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
    • Some alarm attributes do not have a current value in the OPC UA server in the process gateway
      Summary With the OPC UA server in the process gateway, some alarm attributes of an alarm object do not have a value even though an alarm has been active prior to the point in time where the OPC UA server was started. DescriptionWith the OPC UA server ...
