IEC61850 Server - Trying to force an INT32U (and other?) variable to the Server does not work. It is reset to 0
Buffer overrun detection mistakenly found a overrun and read nothing.
Issue Number: 197570
Fixed on Date: 24.10.2019
Versions: 8.00 0 BUILD 62073
    • Checklist: OPCDA Server
    • How can I reset the password of a zenon Service Engine/Runtime User?
      Resetting a password in the zenon Engineering Studio can be essential for maintaining security and managing user access to your project. zenon offers two different methods to reset a password: one through the zenon Engineering Studio and the other ...
    • FAQ: Delayed variable updates on Terminal Server Service Engine Clients occur in some scenarios.
      In some cases, Service Engine Clients on a Terminal Server might have delayed variable updates. Depending on the system those delays can be about 2 seconds. A reason for this can be a hostname resolution procedure, which is needed to determine ...
    • Bug: Write Error to setVal[SP] on IEC 61850 Server
      Description The IEC 61850 Server fieldbus driver accepts the write requests for read-only ('RO') data attributes (variables) with FC=SP; e.g. */setVal[SP]. And it refuses the write requests for data attributes with FC=CF, if SCL-configured as 'Set' ...
