"IEC61850 Configurator" wizard breaks SCL file read.
The IEC61850 Configurator wizard failed to import the SCL file and reported "SCL file is not valid" because it did not skip IEDs whose Communication sections lacked a valid IPv4 address.
  • Update your zenon Software Platform to the latest build of zenon 16 or higher.
Item ID: 319733
Version: 16.00 Build: 650097
