IEC61850 Client drivers – zenon and Logic – are processing consistency scans (acquisition of missing Quality) in Logical Device of RCB, not of Data Object.
Issue in iec850 driver in zenon and IEC61850 Client driver in zenon Logic:
when a Data Set used in Report Control Block (RCB): - contains single Data Attributes (FCDA with daName) - and the FCDA is placed in different Logical Device as RCB - and the IED does not deliver Quality (q-attribute) in reports then the driver processes data consistency scans (polling of missing q-attributes) referring wrong Logical Device. It refers LD of RCB, not of FCDA. As result the driver may behave unstable.
The client now scans missing data attribute q from the correct device.
In zenon Logic - IEC61850 Client - the period of scan is fix – 5 minutes. In iec850 zenon driver this is a setting.
Issue Number: 36828
Fixed on Date: 25.7.2016
Versions: 7.50 0 BUILD 30617
