In zenon Logic the
IEC61850 Client did not write
INT32 negative data correctly. In case of negative values the client sent mathematically correct values but not beginning with the additional
xFF byte.
The issue has been addressed and the IEC61850 Client behavior for sending negative integer values is now as expected.
- Update your zenon Software Platform to the latest build of zenon 15 or higher.
