From zenon 12 on the DIR command did not work correctly anymore. In the Diagnosis Viewer it looked like the command was still executed, but the command variable and "DIR result" variable were not updated correctly.
The issue has been addressed and the DIR command now works correctly again.
Item ID: 288462
Version: 14.00 Build: 314355
Version: 12.00 Build: 301428
