IEC60870-5-104 drivers (master and slave) are loosing redundant connection because of errors in START/STOP procedure implementations
When triggering a manual redundancy switch the IEC60870-5-104 master acknowledges outstanding dl-frames after sending STOPDT. This may cause the slave to ignore the ack or even close the master connection.
there is no workaround, problem depends on timing. Sometimes S-frames is already sent before STOPDT (then is OK), sometimes the order of frames is wrong, then the secondary connection is unstable.
Issue Number: 241254
Fixed on Date: 17.6.2021
Versions: 8.20 0 BUILD 85568 | 10 0 BUILD 85877 | zenon Analyzer 3.40 0 BUILD 87645
