Identity Management offers Service Engine Client and Service Connection Commissioner roles
The following preconfigured resources and roles have been added to allow for more detailed mapping of user rights and related security benefits:
Service Engine Client:
With this role, the Service Engine user administration can be used with the Identity Service of IIoT Services.
This role can only read users and groups. Configuration of the Identity Service cannot be edited by this role.
Service Connection Commissioner:
This role can be used for the connection of a Service Engine to the IIot Services Connection Wizard and for the registration of the Device Agent with Device Management.
Item ID: 233437
Version: 12.00 Build: 153415
Checklist: The Logic Service to Service Engine connection does not work
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
FAQ: When I start my zenon project on a Service Engine client, my AUTOSTART script is not executed. What is the problem?
A "script" in zenon is not a snippet of code as you may think in the traditional sense, but rather a configured collection of zenon functions, executed in order. A common use of a zenon script is to load several screens at project startup, for ...
Checklist: Client/Standby cannot establish a reliable connection with Service Engine Server
