HTML5-Element based 3D element can be used in Windows / Web Visualization Service / Web Engine
A new web-based 3D integration is now available. This can be integrated via ActiveX screen elements.
Only the *.glb format is supported. Functionalities can be triggered in the 3D Integration via limit violations.
A prerequisite for execution is a link to a node in the 3D model via an equipment group.
The Namespace Scada.AddIn.Contracts.Variable in the Interface IVariableCollection was extended by the GetItemsByEquipmentModel method. This allows all variables assigned to an equipment model to be read out.
Item ID: 236365
Version: 10.00 Build: 102631
FAQ: Installation of Service Engine 12 Build 162015 in Ubuntu 22.04 LTS as Docker container
Refer to the attached file: Docker on Ubuntu 22.04 - FAQ.pdf This guideline is solely shared for demonstration and educational purposes. Feel free to contact COPA-DATA Support for further clarifications.
FAQ: Engineering Studio and Service Engine start slowly after Windows Fall Creators Update
Since the Windows 10 Fall Creators Update (Windows 10 Build 1709), zenon is extremely slow when switching between modules or opening dialogs containing toolbars. This mainly affects the zenon Engineering Studio in all versions, but also the Service ...
