HTML Web Engine: Reaction matrix prevents trends from opening
The screen switch function (SSF) is now successfully compiled when an unsupported rema type is detected.
Upon detecting an unsupported rema type in a variable of a curve of an SSF to an ETM which is a gantt curve, this curve is now removed and a respective compiler log message is written.
Issue Number: 238062
Fixed on Date: 2.3.2021
Versions: 8.20 0 BUILD 81129
    • Checklist: HTML Web Engine
      Time estimate: 20 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
    • FAQ: Which IE version is used by the HTML screen? Which Plugins can be executed?
    • "set value" function in HTML Web Engine
      Description When compiling a project for the HTML Web Engine, an error message is displayed for a set value function: "Variable not found." In the HTML Web Engine, the set value cannot be set via a button with this function. The button is not ...
    • FAQ: Open Report Launcher on the web engine HTML screen
      This issue occurs due to cross-site scripting, causing the second HTML screen to be blocked and display a blank screen. It needs to check in IIS if report launcher SSL settings is on "Ignore". And also web engine SSL setting should have the same ...
    • The Message „HTML 5 Web Engine Connecting to server“ appears with connection problem
      Description The Web Engine shows problems and the message "HTML 5 Web Engine Connecting to server" during the connection to the server with the zenon Service Engine Connector. This connection error occurs only sometimes. Cause: A deadlock occurs in ...
