HTML-Screen: WebView2 is available in zenon 10&11
As of zenon 10, WebView2 is used as the browser for the HTML type screen by default. For zenon 10 and 11 CEF can also be activated.
WebView2 is the basis of the Microsoft Edge browser and
replaces Chromium Embedded Framework (CEF) from
Google. As of zenon 12, WebView2 is the only available browser for the HTML screen.
When a current build of zenon 10 or 11 is applied, CEF, if still present, will be replaced by WebView2. If
this is not desired, CEF can be reactivated manually for zenon 10 and 11 by configuring
the zenon6.ini.
In zenon 10 and 11, an entry in the zenon6.ini entry
can be used to switch between Internet Explorer, Chromium and WebView2. This entry is no longer available as of zenon 12.
How to configure the browser for the HTML screen in zenon 10 and 11:
- Open the zenon6.ini.
- Navigate to the [BROWSER]
section.
- Select the desired value for the entry IE=.
Possible
values:
- 0: Chromium Embedded
Framework (CEF).
- 1: Internet Explorer
- 2: WebView2
Note: WebView2 is not available for Windows versions 8 and 8.1 and
older builds of Windows 10. For these versions, WebView2 can be manually
installed.
For information on WebView2 and how to install
it, please visit: https://developer.microsoft.com/en-us/microsoft-edge/webview2/
To benefit from WebView2 with zenon 10 and 11:
- Update your zenon Software Platform to zenon 10 or 11, build 160736 or later.
Item ID: 268008
Version: 10.00 Build: 162215
FAQ: Which IE version is used by the HTML screen? Which Plugins can be executed?
HTML screen: Opening PDF files with extra arguments does not works
Description If additional parameters are specified when opening PDF files via a screen of type HTML, the PDF is not opened when using WebView2. Instead, a "File not found" error is displayed. The use of additional parameters and outputs via WebView2 ...
Browser window in HTML Screen is not correctly displayed with CEF (Chromium Embedded Framework)
Description When using a Chrome-based browser, the HTML image is not displayed correctly in the Service Engine. This issue has been fixed. To display HTML screens correctly in CEF (Chromium Embedded Framework): Update to the latest build of zenon ...
