HTML screen: Opening PDF files with extra arguments does not works
If additional parameters are specified when opening PDF files via a screen of type HTML, the PDF is not opened when using WebView2. Instead, a "File not found" error is displayed. The use of additional parameters and outputs via WebView2 previously worked.
The issue has been addressed. PDF files can also be displayed again with additional parameters via WebView2 in an HTML screen.
Item ID: 280300
Version: 14.00 Build: 239777
Version: 12.00 Build: 232473
Version: 11.00 Build: 392988
Version: 10.00 Build: 391343
    • FAQ: Which IE version is used by the HTML screen? Which Plugins can be executed?
    • FAQ: How to prevent corrupted files after power outage?
      Read the attached PDF files (English/German) for more information on how to set up your system to avoid corrupted files in case of an power outage.
    • FAQ: How to import external vector graphic files in zenon?
      Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
