Historian RDA: Some samples are misdirected into +/-1h files (data source: SQLDRV)
When using the RDA functionality in the Historian, entries are incorrectly saved in files +/- 1 hour to the expected file. The cause lies in the handling of daylight saving time and standard time. When determining whether a time is specified in daylight saving time or standard time, the archives influenced each other, which led to incorrect assignments.
This behavior has been modified. The recognition of daylightsaving time has been adjusted. RDA samples are assigned correctly now.
Item ID: 280340
Version: 14.00 Build: 239777
Version: 12.00 Build: 241649
