Historian Editor tree doesn't update aggregation archive overview after change.
In the Editor Archives tree if you want add new variable via edit archive configuration screen aggregation archive are not up to date with new configuration.
Historian aggregation archive are update with last archive configuration.
Issue Number: 37568
Fixed on Date: 15.12.2017
Versions: 8.00 0 BUILD 46644
    • FAQ: Historian configuration general recommendations
      1. Recommendation on hardware: Storage Memory CPU - High-speed SSD (Solid-State Drive). - Saving Historian data in SQL format requires approximately 4 times more storage space compared to ARX file format. - Disk space capacity as detailed in the ...
    • FAQ: Archive configuration for best SQL evacuation performance
      The time required to evacuate data to a database increases linearly with the number of insert SQL statements. In earlier zenon versions, recorded values were evacuated to the target database sequentially using single-insert statements. From zenon 11 ...
    • Overview of COPA-DATA Online Services: What They Offer and Where to Find Them
      COPA-DATA offers a range of online services to support users of the zenon Software Platform. Below is a brief overview of these services and where you can find relevant information: Online Help Access comprehensive documentation for zenon Engineering ...
    • Historian On change archive in start image stores wrong time
      Summary 'On change' archive in start image stores variables having internal time stamp with wrong time. Description'On change' archive in start image stores variables having internal time stamp with wrong time. Solution Time for a record is now taken ...
    • Historian: SQL evacuation fails with certain archive files
      Description An error occurs in the Historian during the SQL evacuation of archive data. The evacuation fails for certain archive files. This occurs when the last value of a variable is "NaN". In this case, this value is expected to be skipped and ...
