Help button in the startup tool does not always work
The startup tool provides a button to directly open the help document. Actually, this document will only be copied to the hard disc with an editor installation, with a runtime installation the help document is not available and therefore the button doesn't work. However, it is still there and the user can click it which may cause confusion.
The button will now be disabled for runtime installations. Only with an editor installation the button will be enabled.
Issue Number: 31268
Fixed on Date: 12.2.2014
Versions: 7.20 0 BUILD 17768
