Grouped released properties are not found by language table wizard
The Language Table Wizard does not find all new keywords. This has been fixed.
The Language Table Wizard is started with the following settings:
- Convert texts into keywords
- Linked symbol
With these settings all new keywords of
released properties should be found and created. However, keywords for grouped
properties are not found during the search. These must be added manually later.
This
error has been fixed. Now all new keywords are found even if they are in
grouped properties.
- Update your zenon Software Platform to
the latest build of zenon 11 or higher.
Item ID: 258784
Version: 11.00 Build: 115310
Language table wizard corrupts project
Summary Running the Language Table Wizard corrupts the project. This has been fixed. Description The Language Table Wizard causes errors when run with the options "Convert texts into keywords" and "Linked symbols". The entries in the language table ...
Styles can not be changed/assigned in grouped released properties" of a symbol"
Summary After loading a screen/symbol that contains a symbol link, all values of the style properties are displayed again. Description After loading a screen/symbol that contains a symbol link, all values of the style properties are displayed again. ...
Released symbol properties disappearing in Engineering Studio
Description In the Engineering Studio properties of a symbol can be released. In some constellations, these released properties are no longer displayed when clicking the symbol. This display error has been fixed. All released properties are displayed ...
zenon Editor – language table. Opening the language table could cause a memory leak.
Summary When opening the language table at the zenon Editor it may occur a memory leak of approximately 10 kb for each opening of the language table. Not reproducible with an empty zenon project. DescriptionWhen opening the language table at the ...
Keywords are not translated via the language table.
Summary The string Creating list... or Liste wird erzeugt... will be shown when the CEL/AML is being populated isn't translated via the language table. Description The string Creating list... or Liste wird erzeugt... will be shown when the ...
