Group specific automatic logout time edit in runtime does not work correct if a larger value is entered than the maximum possible
Entered values in field "automatic logout time" in user group edit screen are not checked for valid range
Issue Number: 237611
Fixed on Date: 10.2.2021
Versions: 8.20 0 BUILD 80611
    • It is not possible to edit the user group's authorization levels in the runtime.
      Summary In the runtime, it is not possible to edit a user group and change the authorization levels for the group. An Admin user should be able to edit user groups and set authorization levels for the user groups. (only those authorization levels ...
    • FAQ: What is the time zone and time format used in zenon Software Platform products and what needs to be considered?
      When you ask someone what the time is, they'll usually be able to tell you. But when you ask them what date and time sunrise was yesterday in a different country on a different continent, in a different hemisphere it gets less easy. Terms like GMT ...
