GraphQL - Wildcard * sometimes not working for Recources Label and Identification
Filters in GraphQL interface sometimes do not provide desired results. If filtering on an empty string, only those objects are displayed that have an empty string at the filtered items. However, the filter should be disabled and show all data.
This behavior has been fixed.
The filters now work as intended:
  • Filter not present: all data is returned
  • Filter set to "*": all data is returned
  • Filter set to an empty string : filter is disabled, all data is returned
Item ID: 257125
Version: 11.00 Build: 111398
