When certain Add-Ins
are called multiple times, unusual memory usage occurs. The memory used is then
not released again. This is due to the behaviour of the .Net Framework, which
can lead to memory leaks during certain actions.
A workaround solution has been deployed for this behavior. This changes the loading behavior of Add-Ins Please also note the side effects of this solution!
Solution:
Configure the loading behavior of Add-Ins in zenon6.ini.
1. Open the zenon6.ini.
2. Search for or create the [ADDINS] section.
3. Configure the entry "LOAD_ADDINS_IN_DEFAULT_APPDOMAIN".
- 0: Add-Ins are loaded into private AppDomains
- 1: Add-ins are loaded into the default AppDomain
4. Activate the switch by setting LOAD_ADDINS_IN_DEFAULT_APPDOMAIN=1.
This forces the loading of Add-Ins into the default AppDomain and prevents memory leaks caused by .Net Framework.
Attention: This means that it is no longer possible to reload Add-Ins. Extensions and assemblies that are consumed by the loaded add-in can no longer be updated as long as the Service Engine is running.
