Function / Script node at the project tree of the zenon Editor. Icon is displayed incorrect.
In the new script selection dialog the icon in the top left corner is displayed wrong as if it has reduced colours.
Enhancement for all selection dialogues was implemented. Now, all icons for all selection dialogs (Variables, Functions, Remas, Batch..., Users, ...) use the full colour depth (24 bit) from the bitmap file.
Issue Number: 32673
Fixed on Date: 23.12.2015
Versions: 7.60 0 BUILD 36068
FAQ: HTML Web Engine: How is it possible to always jump to a specific start-screen after refreshing or reloading a Web Engine Website?
A specific start-screen can be open using the built-in solution automatic script call. See : Online Help: Individual Script call in HTML5 Web Engine . Nevertheless, this will not cover a reloading web-engine (e.g. after updating the .webx files, ...
Output window: "Report Viewer: export/print" function provides incorrect warning in the output window
Summary The "Report viewer: export/print" function issues incorrect warnings in the output window. This has been fixed. Description Under certain conditions, the "Report viewer: export/print" function issues incorrect warnings in the output window. ...
Fieldbus configuration: uncomplete display in the tree for the root node
Summary In zenon Logic, some values are not displayed when reopening the Fieldbus configuration. This error has been fixed. Description In the "Fieldbus Configurations" editor, for entries in the tree of the root node, the names and values of the ...
