Function "Execute VSTA Macro" is not executed in zenon 12 for converted projects
When converting a project to zenon version 12, the "Execute VSTA macro" function is not applied correctly. The VSTA code is not executed. However, the same code is executed if it is part of the "ThisProject_Active" or "ThisProject_InActive" event. These events are triggered correctly.
This error has been fixed. The "Execute VSTA macro" function is converted correctly to zenon12 again. The VSTA code is executed.
Item ID: 271608
Version: 12.00 Build: 206562
