Function block DT2UNIX in the zenon logic runtime contains an incorrect result of the date conversion
The function block D2TUNIX incorrectly converts the time to a unix time.
An issue has been addressed in the D2TUNIX function block in the zenon logic runtime. Now the function block uses a 64 float instead of a 32 bit float and the converted UNIX time is correct.
Issue Number: 28529
Fixed on Date: 8.1.2013
Versions: 7.00 0 BUILD 6
