From time to time, at 000ms, zenon Process Gateway sends values with incorrect timestamp.
From time to time and only when variable timestamp has 000ms, the zenon Process Gateway (e.g. IEC870 Slave) sends incorrect timestamps with 1 second back in time.
Issue was addressed in gateways: AccessIEC870Sl, AccessAzure and AccessDNP3.
Issue Number: 33631
Fixed on Date: 27.2.2015
Versions: 7.11 0 BUILD 18023
Checklist: Process Gateway cannot establish a reliable communication
Checklist: Process Gateway cannot start
Historian: At reload an old value is written again / received values with old external timestamp not discarded
Description In the Service Engine, data from already closed archives is written to the current, open archive capsule in the Historian. This problem can occur: By project reload. If the PLC sends variable values with an external timestamp from the ...
