Fritz!Box VoIP: Voice transmission fails
When using a Fritz!Box, the voice transmission via Message Control fails. This has been fixed.
A transmission error occurs with Message Control
when using VoIP with an intermediary VoIP server such as the Fritz!Box.
Cause:
An intermediary VoIP server can cause voice
transmission errors.
Solution:
Configure the new parameter provided in zenon6.ini
for this purpose.
[MESSAGECONTROL]
VOIP_ALLOW_SDP_NAT_REWRITE=1
This entry controls whether the IP address in the SDP
should be replaced by the IP address from the via header of the REGISTER
response.
Set this entry to 1.
Message Control will then use the IP address communicated in the via header.
To benefit from this
fix:
- Update your zenon Software Platform to the latest build of zenon 8.20
or higher and configure your zenon6.ini accordingly.
Item ID: 264622
Version: 11.00 Build: 157700
Version: 10.00 Build: 144352
Version: 8.20 Build: 150600
FAQ: Message Control || VoIP message is sent but can’t be heard
In a VoIP message the audio file can use several codec formats for its compression. When a call is set up, then sometimes some target providers already play back the ringing to the call as an audio stream. This can be done in several or one specific ...
FAQ: What are the modems successfully tested with zenon Message Control?
The list of tested modems is available in the pdf file attached. Unfortunately, old analog voice modems are rare on the market and the drivers for these devices are not available for actual operating systems like Windows 10, Windows Server 2016, etc. ...
ServiceEngine sometimes crashes if VoIP server cannot be reached
Description The zenon Service Engine closed unexpectedly sometimes if VoIP could not be reached. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software Platform to the latest build of ...
