Frame reference points are not correctly used on Multimonitor Systems
Reference points for pop-up screens are not used correctly on multi-monitor systems. This bug has been fixed.
When using multiple monitors, pop-up screens may not be displayed correctly. The “relative to element” setting for the “Positioning” property is used to configure how a pop-up screen is switched on. While the pop-up screen on monitor 1 is displayed at correct distance relative to the reference point, it is positioned incorrectly on monitor 2. Also the alternative reference point, which is correctly used as a substitute on monitor 1, is not used on monitor 2.
The cause of this bug is the method used to validate the limits of “relative to element”. All calculations were based on the size of the virtual screen, i.e. the total size of all screens.
This has been modified, now the coordinates of the current monitor on which the element must be positioned are used. This means that pop-up screens are displayed on all monitors at the correct distance from the reference point.
Item ID: 286055
Version: 11.00 Build: 282289
Version: 10.00 Build: 277009
