Filter Controls are missing in Manual Data Editor
The Manual Data Editor does not display any filter rows for
the column headers. The same applies to the dialog for calculated archives in
the Reporting Studio.
This error occurs since build 171299 for
versions 10, 11 and 12.
This error has been fixed. The filter row is displayed
again as expected.
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 270769
Version: 12.00 Build: 180966
Version: 11.00 Build: 176384
Version: 10.00 Build: 176923
How to use the IIoT Dashboard Service
In this article you will get an overview of how to use the Dashboard Service with data from the zenon Service Engine. This service is available with IIoT Services 14.1. Prerequisite: You have connected a Service Engine to the IIoT Services and you ...
