Files that are not overwritten by the build setup should be logged in the log file
If a file in the ProgramData folder was changed by the user, the build setup does not overwrite the file. There is no information in the logfile that the file was not overwritten.
 If a file in the ProgramData folder is modified by the user since the original installation, the build setup will not overwrite the file and an entry in the logfile is made.
Issue Number: 30070
Fixed on Date: 30.7.2013
Versions: 7.10 0 BUILD 6919
