FileManagerFolder object for tpPathReport (*.xrs report files) is always null
When trying to assign the FileManagerFolder object with the enum tpPathReport, the return value is always null.
An issue was addressed in the programming interfaces. Now, the FileManagerFolder object for reports is properly returned.
Issue Number: 34001
Fixed on Date: 18.3.2015
Versions: 7.20 0 BUILD 18778 | 7.50 0 BUILD 25796
FAQ: How to prevent corrupted files after power outage?
Read the attached PDF files (English/German) for more information on how to set up your system to avoid corrupted files in case of an power outage.
FAQ: How to import external vector graphic files in zenon?
Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
IEC850 GETDIFF transfers always all files.
Description The IEC850 GETDIFF command transferred all files, including already present ones, because the file-listing function used the search mask appended to the path instead of supplying separate path and mask. The issue has been addressed and ...
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
Checklist: Checklist for Report Engine errors
If the following error appears, please check the following: Error message: 1. Check the license: All components that have been installed must be licensed, such as : - the installed Report Engine version - Service Hub - Service Grid - Identity Service ...
