File transfer in control direction for the IEC60870 slave for zenon logic
Is file transfer in control direction supported for the IEC 60870 slave for zenon logic?
The IEC 60870 slave for zenon logic has been enhanced with a configuration option for specifying the directory for file transfer in control direction. File transfer is in control direction is now also supported.
Issue Number: 218316
Fixed on Date: 1.9.2020
Versions: 8.20 0 BUILD 68579
IEC870 driver (Master) and zenPG IEC870Sl should support file transfer also in control direction.
Summary We will introduce for 7.20 and we already successfully tested a new functionality in our IEC60870-5-101/104 products - file transfer in control direction. This means transfer in "reverse direction" - from Master to Slave. We need this feature ...
Checklist: Message Control
Checklist: Configuring the FTP Function Block in Zenon Logic
FTP Connection Parameters: IPServer: The IP address of the FTP server. IPClient: The IP address of the computer where the data will be transferred. UserName: The username for accessing the FTP server. Password: The password for accessing the FTP ...
