File Inspector: Opening files via File menu throws an unhandled exception
When opening files in File Inspector via the File menu, File Inspector crashes with an unhandled exception. However, opening files via Drag&Drop works. After opening a file via Drag&Drop and restarting File Inspector, other files can also be opened via the menu.
This error has been fixed. Files can be opened normally again via the File menu.
Item ID: 266461
Version: 12.00 Build: 159727
