File Inspector: Opening a File via Open menu points to System32 folder
When opening a document in the File Inspector
via the menu, the System32 folder is incorrectly offered as the source.
Correct would be the default LOG folder of zenon: "C:\ProgramData\COPA-DATA\LOG".
If this is not available, the "Documents" folder should be
offered.
This behavior has been modified. When opening a
document, the default LOG folder of zenon is offered again.
higher.
  Item ID: 268535
 Version: 12.00 Build: 206562
- Related Articles
- File Inspector: Opening files via File menu throws an unhandled exception- Description When opening files in File Inspector via the File menu, File Inspector crashes with an unhandled exception. However, opening files via Drag&Drop works. After opening a file via Drag&Drop and restarting File Inspector, other files can also ...
- File Inspector: FI cannot open database- Description The File Inspector could not open the Engineering Studio SQL database 2022 which is used for zenon 14. The issue has been addressed and the File Inspector can open the database now. To benefit from this fix: Update your zenon Software ...
- File inspector cannot open .CEL files- Description When trying to open a file of *.CEL format in File Inspector, the error message "Directory not found" is displayed. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software ...
- Restore missing project database instance via attaching an .MDF file or System Information Collector (SIC)- One may encounter this scenario, where a project instance is absent from the database and cannot be opened in the Engineering Studio. This may happen if, for example, you uninstall zenon and did not create a project backup. NOTE: It is highly ...
- File Inspector: It cannot open specific ARX files (healthy)- Description In version zenon 14, the File Inspector generates a parsing error when trying to open properly saved ARX files. This bug has been fixed. ARX files are opened successfully again. To benefit from this fix: Update your zenon Software ...
