File Inspector: Error message is thrown when attempting to open a file after drive is disconnected
If a file is opened on an external drive in the File Inspector
and the drive is then removed while the File Inspector
is closed, the File Inspector is no longer able to open a file after it is
restarted. Clicking on "Open file" leads to an exception
error. It is not possible to select an alternative source instead of the
removed drive.
This error has been fixed. The "Open file"
dialog works as expected, even if a previously used drive has been removed.
higher.
Item ID: 274662
Version: 12.00 Build: 232473
Version: 11.00 Build: 231258
FAQ: What can I do if the Service Engine does not start or is closed with an unhandled exception and the error message "(InitInstance (); an unnamed file has a bad format)" or "Init Instance (): an attempt was made to access an unnamed file past its end" is shown?
This issue may occur due to missing digital certificates on the system where the error appears. Microsoft Windows implements a mechanism that automatically downloads, over the internet, trusted root certificate authorities, which are not installed ...
File inspector cannot open .CEL files
Description When trying to open a file of *.CEL format in File Inspector, the error message "Directory not found" is displayed. This error has been fixed. To benefit from this fix: Update your zenon Software Platform to the latest build of zenon 11 ...
Checklist: Message Control
File Inspector: Opening files via File menu throws an unhandled exception
Description When opening files in File Inspector via the File menu, File Inspector crashes with an unhandled exception. However, opening files via Drag&Drop works. After opening a file via Drag&Drop and restarting File Inspector, other files can also ...
File Inspector: Opening a File via Open menu points to System32 folder
Description When opening a document in the File Inspector via the menu, the System32 folder is incorrectly offered as the source. Correct would be the default LOG folder of zenon: "C:\ProgramData\COPA-DATA\LOG". If this is not available, the ...
