Fieldbus configuration: uncomplete display in the tree for the root node
In zenon Logic, some values are not displayed when reopening the Fieldbus configuration. This error has been fixed.
In the "Fieldbus Configurations"
editor, for entries in the tree of the root node, the names and values of the
properties are displayed. After saving and closing the editor, only the names
are displayed when reopening. The values are ignored and are not shown.
This error has been fixed. All expected data is
displayed again in the “Fieldbus Configurations” editor.
- Update your zenon Software Platform to the latest build of zenon 12
or higher.
Item ID: 284922
Version: 14.00 Build: 275981
Version: 12.00 Build: 272744
renaming the root node "Units" of the Batch Contrl tree has no effect
Summary The module Batch Control has its own tree in the editor where unis and their phases are displayed. The root node of this tree can be renamed. This has, however, no effect as the modification is not stored. Description The module Batch Control ...
XML Export: fieldbus documentation does not export correctly the properties of the root node
Description The XML export of the drivers (except MODBUS) did not export the properties of the root node correctly. The issue has been addressed and the behavior of the XML export is now as expected. To benefit from this fix: Update your zenon ...
Interface settings for using an Ethernet port for Fieldbus communication in zenon Logic (e.g. ProfiNET)
When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf. IEEE802.1Q) are deactivated in the network adapter configuration. Therefore, go to the Network controller ...
If project is set to Windows CE, the node VSTA is still visible in the project tree
Summary If project is set to Windows CE, the node VSTA is still visible in the project tree, yet VSTA is not available under Windows CE. Description If project is set to Windows CE, the node VSTA is still visible in the project tree, yet VSTA is not ...
Since 7.50 in Equipment model the tree layout disappears while deleting some node in another window with Equipment model.
Summary The Equipment model may be opened simultaneously in two windows, e.g. from properties dialog and as general window. In that case when you delete a node in the tree opened form properties dialog then all the content in other window disappears. ...
