The most common ones are:
- The zenon Historian
- The Extended Trend
- The zenon Report Generator
- The zenon Report Engine
- The zenon SQL export functions
- The zenon SQL Driver and
- The zenon Process Gateway SQL module
All these modules depend on an ODBC / OLEDB connection to the database used. These drivers are normally delivered by the database vendor (e.g. Oracle or Microsoft) and installed on the Operating system. Once the drivers are in place the SCADA Engineer is able to configure the necessary connections Strings directly from the zenon Engineering Studio.
