Many email
providers require the use of app passwords when accessing their services
through third-party software. If you need to use SMTP or POP3 (or IMAP) to
access your email, you will need to generate an app password specifically for
that software. To create an app password, you will need either the provider's
app or an authenticator (like Google Authenticator) to confirm the code after
enabling two-factor authentication.
App-Password
should be activated as follows:
1- In the Email-Provider, activate two-factor authentication
2- Authenticate your password with the Provider's app or another authentication
method
3- On the Provider settings page, you can enable App-Password
4- Make sure to copy your App password, as it will only be shown once. If you
miss it, you'll have to create a new one.
5- App-Password can be used in 3rd party software
To set up
your email account, you can use the following ports and encryption methods:
- For
outgoing emails, you can use ports 465 or 578 with SSL or TLS1.2 or higher
encryption.
- For
incoming emails, you can use ports 995 or 993 for POP3 or IMAP with TLS1.3
encryption, which is mostly used by modern providers.
* You can
set TLS in zenon6.ini if you're using Zenon version 10.
FAQ: Message Control || VoIP message is sent but can’t be heard
In a VoIP message the audio file can use several codec formats for its compression. When a call is set up, then sometimes some target providers already play back the ringing to the call as an audio stream. This can be done in several or one specific ...
Retry sending message via GSM SMS or SMTP mail have not correct try count and last send try timestamp.
Summary When sending a message via the GSM SMS dispatcher or the SMTP mail dispatcher fails due a hardware failure (no modem connected, no network connection, wrong phone number or email), the last send try timestamp and the send try count are not ...
Message Control SMTP sending type: Not robust against lagging SMTP connection
Summary The message control engine tried to send the EHLO before the received server greeting was fully received (due to lagging connection - there was just one receive attempt without timeout). Now, the engine uses a 10 second timeout for completely ...
Checklist: Message Control
Chinese character in the SMTP message control function becomes the question mark in the email
Summary SMTP mails use US-ASCII encoding by default, which does not support all characters. Message Control now explicitely sets the encoding to UTF16 allowing much more characters like chinese, korean, japanese, cyrillic, arabic, ... Description ...
