FAQ: I would like to create XML Import files manually outside from zenon. Is there a schema definition to validate such XML files?
For the zenon XML Formats there are actually no style definitions available or documented. We recommend to use an exported file (e.g. from the Engineering Studio) as a basis for the manipulation. That's the best way to ensure a proper format of the XML file.
    • FAQ: How to import external vector graphic files in zenon?
      Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
    • FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
      What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
    • FAQ: How to prevent corrupted files after power outage?
      Read the attached PDF files (English/German) for more information on how to set up your system to avoid corrupted files in case of an power outage.
    • FAQ: How can I browse an OPC UA Server using the zenon OPC UA Client Driver?
