Sometimes it can happen that old/deleted/corrupted screens are still in the project-SQL directory (C:\ProgramData\COPA-DATA\SQL[VERSION]\[PROJECT_GUID]\FILES\zenon\system\pictures). Once you know the corrupt file in this folder you can delete it and ...
Password.cmp having version 0 indicates that this file is corrupt. Mostly this happens if the zenon computer is switched off by interrupting the power supply but not shutting down the system proper. As zenon runs on Windows systems it is needed to ...
Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
Summary If ARX file is corrupted by padding zeros it is overwritten by a empy one at runtime startup. Description If ARX file is corrupted by padding zeros it is overwritten by a empy one at runtime startup. Issue Number: 209912 Fixed on Date: ...
