FAQ: How does zenon support multicore processors, multithreading and 64-bit operating systems?
Read the attached PDF (available in English and German) to get explanations about zenon on 64-bit environments, multicore processors and multithreading.
As a generic rule COPA-DATA recommends that the operating system is always kept current and that the security updates at least are installed. Check updates on your own system(s) before installation for possible interaction with the zenon software ...
We recommend to use the newest version of zenon in the most recent Operating Systems as COPA-DATA can neither release or support old product versions in newer Operating Systems.
Summary Solution Depending on the app functionality, various mobile operationg systems are supported. The apps do not offer automatic adaption to the resolution. They are always displayed in a default resolution. For example: Notifier-App by zenon: ...
Description The number format from the operating system configuration which is not supported by the MSI Interface, prevented the message from being sent correctly. The issue has been addressed and the message is sent now correctly. To benefit from ...
Description In the Edge Gateway frontend, the user password can no longer be changed in MS Active Directory, when the zenon system is not a member of the domain. Despite correctly entering the previous password and the new password including password ...
