FAQ: Are products in the zenon product family affected by Node2Shell (CVE-2026-111497)
Quick Information:
  1. On October 21, 2026, a critical vulnerability in the Brotli decoder used by Node.js was disclosed, commonly referred to as "Node2Shell" (CVE-2026-111497).
  2. The zenon Engineering Studio is affected in a specific scenario involving the HelpNavigator component.
  3. The vulnerability is caused by an out-of-bounds write in the Brotli decoder of Google.
Info
As a software manufacturer, COPA-DATA takes security and the protection of its customers and partners very seriously.
This FAQ provides information about the recently disclosed Node2Shell vulnerability and clarifies its impact on the zenon Software Platform, including the relevant exploitation conditions and recommended mitigation measures.
What is the vulnerability called "Node2Shell"?
On October 21, 2026, the Node.js development team released security updates addressing a vulnerability in the Brotli decompression library used by Node.js.
The vulnerability, identified as CVE-2026-111497, is commonly referred to as "Node2Shell", "Broccoli2Shell", or "HTTP2Shell".
An out-of-bounds write vulnerability in the Brotli decoder can cause memory corruption when processing specially crafted Brotli-compressed data. Under certain conditions, an attacker may exploit this behaviour to disclose sensitive information, cause a denial of service, or potentially execute arbitrary code.
Key properties
  1. Successful exploitation may result in memory corruption, information disclosure, denial of service, or remote code execution.
  2. The vulnerability affects applications using vulnerable versions of the Brotli decoder, including certain Node.js versions.
  3. The Node.js project has released security updates addressing the vulnerability, including Node.js versions 22.23.4, 24.22.1, and 26.12.1.
How is the zenon Software Platform deployment impacted by "Node2Shell"?
Based on the current investigations, the zenon Engineering Studio is affected by CVE-2026-111497 in a specific scenario involving the HelpNavigator component.
The HelpNavigator is used to access help documentation within the zenon Engineering Studio, for example when opening context-sensitive help using the F1 key.
The affected scenario is subject to the following conditions:
The HelpNavigator uses help files stored locally in the "C:\ProgramFiles"-directory on the workstation. If these files were tampered with or replaced the vulnerability can potentially be exploited.
According to the current analysis, exploitation of the vulnerability in this scenario requires local or physical access with administrative privileges to the affected zenon Engineering Studio deployments.
COPA-DATA's impact analysis and threat assessment indicate that successful exploitation under these specific conditions is very unlikely.
At present, COPA-DATA is not aware of any reports of active exploitation of this vulnerability in installed zenon environments.
  1. The described impact is limited to the identified HelpNavigator scenario within the zenon Engineering Studio. The general potential for remote exploitation of Node2Shell in other applications does not imply equivalent remote exposure of the zenon Software Platform.
Are security updates planned?
Yes. The affected component has already been updated internally to address the vulnerability.
The updated component is currently undergoing the release process and will be included in one of the upcoming zenon BuildSetups for:
  1. zenon 12
  2. zenon 14
  3. zenon 15
  4. zenon 16
The corresponding BuildSetups will be available through the COPA-DATA Product Downloads.
For additional questions a ticket can be opened for registered users.
Are .NET runtimes affected by CVE-2026-111497?
Yes. The vulnerability also affects certain versions of the Brotli decoder included in Microsoft .NET runtimes.
Microsoft has released security updates addressing CVE-2026-111497 for affected .NET versions.
The actual exposure depends on whether an application processes untrusted Brotli-compressed data. Installing a vulnerable runtime alone does not necessarily mean that the vulnerability can be exploited.
Nevertheless, applying the available runtime security updates is strongly recommended as a preventive security measure.
Minor Versions of the .NET runtimes can be updated through the .NET downloads page or can be automatically updated via Windows Update settings.
Alert
COPA-DATA strongly recommends that Asset Owners and System Integrators keep systems up-to-date with the latest security updates.
References for Windows .NET
  1. Update other Microsoft products | Microsoft Learn
  2. Browse all .NET versions to download | .NET
Until the updated zenon BuildSetup is available and installed, COPA-DATA recommends that Asset Owners and System Integrators implement the following security measures:
  1. Apply the latest available security updates for the .NET runtimes installed on Windows systems. This is strongly recommended independently of the HelpNavigator-specific mitigation measures.
  2. Prevent unauthorized local or physical access to workstations running zenon Engineering Studio.
  3. Restrict unauthorized modification of application directories, locally stored help files, and other resources used by the zenon Software Platform. Ensure that only authorized users can modify or replace these files.
  4. As a temporary mitigation, the HelpNavigator component (by-default 'C:\Program Files (x86)\Common Files\COPA-DATA\HelpNavigator\Viewer\') can be removed or the 'zenHelpService' service stopped if its functionality is not needed.
  1. General hardening recommendations
COPA-DATA recommends to follow the hardening recommendations outlined in the COPA-DATA onlineHelp for the corresponding versions of the zenon Software Platform.
Use appropriate endpoint security solutions, such as antivirus software, endpoint detection and response (EDR), and application allowlisting. Monitor systems for suspicious activity or unexpected application behaviour.
Separate the zenon Engineering Studio from untrusted networks and restrict unnecessary network communication. Allow only required connections and services according to the necessary requirements of the environment.
Initial release date: 03/11/26 - Edited: 04/11/26
Publishing Authority: COPA-DATA PSIRT
References
  1. Node.js — Wednesday, October 21, 2026 Security Releases
  2. Node.js — Node.js 22.23.4 (LTS)
Notes
The content of these links is not managed by Ing. Punzenberger COPA-DATA GmbH.
